1 - 9 of 9 Posts
how hard would it be to swap my lift to another persons truck and put there stock suspension back on mine without a lift. and how long would it take
Just depends on how much lift, what all has been changed, and what kind of shape the parts are in. Shouldn't be too bad.
Depends on a couple things, mainly whether you get stuck somewhere or break something and have to wait on parts. But if nothing goes wrong figure a weekend of work for each truck maybe a couple days more if its your first time.
Trucks side by side in the same garage, three or four people working, I'd say a weekend fairly easily if you don't have any unexpected problems,, (Broke parts) etc...
These being straight axle trucks, the lifts are not that complicated I'm sure. I installed an IFS in my 90 Chevy all alone, with no lift.
if its the 02 in your sig it has strait axle? I put my lift on in about 3 hours give or take a couple minutes (two people working on it and no lift just jack stands and jacks) I had 6 inch lift and 37's. we swapped a ifs duramax 6 inch lift from one truck to another and that took about 6 hours both without post lifts.. all depends on if something breaks and how dedicated you are.. but not alot goes into solid front axle lifts.
hahahaha not solid front axle... mean coil vs. leaf springs sorry been at work for 12 hours now ha
Jack Ken
We did it in a drive way (not ours either) in about 3 hours. There were 4 of us and only 2 of us KNEW what we were doing. That was an 00 with 8in lift.
Discussion Starter #9
it's my 02 so i'll just block up under the frames how do i make sure i get the axles straight
1 - 9 of 9 Posts
