1 - 2 of 2 Posts
Ok so I'm to the nation of powerstrokes..... I need some help I ordered a set of 20x12 wheel with 0 offset and 4.52 backspace.... I know I have to lift the 2wd and I have a 2" leveling kit already but I was told that the 05 and up coil spring will fit the 99's..... so my ? Is can I run the 05 and up 2.5 lift springs with out all the brackets like the 6" lift needs...some one please help
I had a 99 I did the 6inch fabtech I don't think just changing out coil springs will work that is a ibeam suspension so you need the brackets to correct all the suspension geometry so you don't have alignment problems.Hope that helps you out man.
1 - 2 of 2 Posts
