1 - 6 of 6 Posts
whats a good leveling kit to buy?
i dont want to spend 1000$ on a icon or carli but i do want to keep a factory ride
i want to be able to run 35's on factory 20's with no rubbing
thanks guys:dfpsn:
I be shufflin
Ready lift has a really good set-up, 3.5" and looks damn nice check em out!!
that kit is still 799$
i want way lower than that for right now..lol
I installed the autospringcorp.com. It comes with the 2" coil spacer and shock extension. It was $ 146 includes shiiping. You also want to get the truck aligned after you add this kit, that was $ 89.
I did a truxx leveling kit thru auto anything for 235.00 shipped no tax. it comes with a 2 1/2 inch front spacer, shock extendors for the front, rear 3 inch blocks, set of longer u bolts. I was very pleased with it and the price. The only thing is I wanted a little rake on mine for when I tow so I replaced the 3" blocks with 4". Here are some pics the first has the 3" block the second already has the 4" block. Absolutely no rubbing at all running 35x12.5 toyo open countrys on factory wheels. My buddy has the same kit on his 2011 with the same results. Hope this helps
1 - 6 of 6 Posts
