1 - 10 of 10 Posts
Got a tuff country
add-a-leaf leveling kit came with leafs center bolts and 8 nuts which I'm guessin are for U bolts but was I supposed to get new U bolts or will the old ones work? tryin to put it on now so any help would be great.
Thanks, Rykan
Thank you!!!! Been waitin around to do this all day wasn't sure so I didn't pull it apart lol
<-MONEY PITT!!
:whs:Make sure to retighten them after a few hundred miles!!!
Lost Cause
for the easy of the installation, get new u-bolts. Cut the old ones off instead of dealing with penetrating fluids and torches.
Alright update got everything pulled apart and it is a rough country add a leaf not a tuff country. Are the extra leafed supposed to be a good but shorter? Got 4 bolts with it but only place I can find a place for bolts are the center pins and the 2 that fit in good there seem to be awful long. Also what keels them from moving side to side?
In starting to wonder uf they sent me the wrong one
Not all 4 bolts are the same 2 are bigger and seem to fit in the center pin place nicely the other 2 are a bit smaller
1 - 10 of 10 Posts
