1 - 13 of 13 Posts
Well I have gotten tired of how low my front end sits, so I am wondering if anybody knows of some good leveling kits? I'm shooting for a 2.5" lift on front.
depends on what you want to spend, my 01 I did 2" (cost about 250. 12 years ago) but it raised it more like 3.5", I eneded up putting bigger block in rear casue front was rasied to high
my 99 I have now has ICON LK, it had what I think was a 4" lift and I didnt like the ride so my friend sold me the LK w/ bitsien shocks for 100 bucks( good friend), but anyway, I was wanting the truck to come down some cause the 35's don't fill the wheel well, but it only came down about 1/2" if any so in my experience the LK will raise truck more than rated, but I would search forum for others input
http://iconvehicledynamics.com/shop/complete-suspension-systems/14-2000-2004-ford-f250-f350-superduty-3-lift-hanger-system.html
Thanks for the info. I will do a little more research and see what I find.
Kris
On my 2000 I just bought leveling shackles. Roughly $50 off eBay. I've been abusing my truck for a year now with it and no problems.
Just want to level it out or run larger tires too? 33s max with it leveled. Super Dutys look perfect with a 4" lift and 35s. JMHO
Kris
I agree that a 4" and 35's looks great. That's my plan for the future.
Right now i'm sitting on 33's with a leveling kit.
For right now I'm just leveling it. I might throw some 33s on it but idk yet.
350 rear blocks and leveled in the front could clear 35's with correct back spacing.
Kris
Mine is an F350. I wouldn't try clearing 35's, it would be a hair from rubbing if it didn't rub. You probably could, but I hate to see a tire rubbing.
Don't run $50 leveling shackles on the front. It will put your front driveshaft at a bad angle and when your in 4x4 your truck will vibrate. Trust me! I did it. Correct way to level is with lift springs. Cost me $ 260 bucks for both sides off of ebay.
I just took mine down to the local spring shop they measured it and added a leaf to the front about 2.5 " lift sits about a 1/2" lower than the rear looks about right its a f350 running 295/75/16s on toyo at2s on stock wheels they are about 33.5" tall.35s would probably clear but would rub the front leaf springs at full lock.
powersmoke
changed my rear springs because they broke and used bottom leaf from old springs leveled it perfect and it was free had to get longer u bolts though and center bolt
1 - 13 of 13 Posts
