1 - 8 of 8 Posts
I changed my fuel filter and now I have a leak at the back of the fuel bowl. I think it's the yellow lever. Is there a fix for this.
o-rings
Guzzle has everything you need
Old Yeller, REBORN
Open and shut it a few times to exercise the valve a bit. This may stop it until you change the orings.
I took it off and flipped the orings over and put it back on. It's leak free now. Buys me some time to order them and get them replaced.
was it draining out the tube or leaking into the valley. I noticed mine was leaking out the drain tube yesterday. Really strange....
Old Yeller, REBORN
OK, that makes sense then. Excersizing the valve would only fix the drain tube leak wouldn't it?
Strokin it in your face!
reason the o rings go out is not using fuel additive whenever you fill up, the additive helps prevent them from corroding... since the fuel we put in our trucks is [email protected] theses days..
1 - 8 of 8 Posts
