1 - 3 of 3 Posts
I bought my 2000 f250 last fall. It came with 32" tires that rubbed when I turned. I then decided to install a 2 1/2" leveling kit. Last week I finally installed the kit and got more than needed. My kit is a zone offroad leaf spring pack. I like the way my front end looks now but it sits 1 1/2" higher than the front.
I want to lift the rear to level the truck but I need some advice before buying parts.
I do not want to add blocks.
Will new springs lift it enough or should I just add springs?
Administrator
Just buy some f350 blocks. They are 2" taller than f250 blocks. Simple.
Super Moderator
Cheapest solution is the F350 blocks.
For new rear springs you would make sure they are 2" of lift. You could use an "mini spring pack" to the rear for the same solution.
1 - 3 of 3 Posts
