1 - 18 of 18 Posts
I installed new batteries in my truck back in December. Up until last Friday I had not had any problems. While out doing some running last Friday I noticed that the truck seemed to be turning over slower while trying to start it. Needless to say it finally got to the point it won"t start. I'm guessing maybe the alternator but wanted to see what you guys thought.
Thanks.
Outlaw wrench
Pull the starter and have it tested.
I would get the batteries load tested first. If they are good then charge them, and get the alt load tested.
Don't screw around to long get them load tested and find the problem because weak or bad batteries will kill the FICM they run from 300$ to 1100$ and in time it will screw up the injectors also:doh:
2 stroker:fordoval:
Ok I'm gonna try to charge the batteries so does it matter which battery I hook the charger to.
Thanks
Haters Gonna Hate
No, just get it hooked up.... was the battery light on your dash on when you were driving it?
burning mine saving yours
Are you on your original alternator? Get it tested sounds like it would be a good place to start with relatively new batteries that are now dead. Do yourself a favor and stay away from the autozone alternators. Yes they have lifetime warranty but in 6 months i went through 4 off the shelf reman alternators before i finally replaced it with a mean green alternator.
I'll second staying away from az Alts. I don't recommend using any if there electric parts. I have a buddy who bought an alt from them in febuary. I told him they aren't worth crap, but he wanted me to put it on anyways. I did, and just mon he called and said it wasn't charging. So I took it back to az and made them load test there's new in box at the store. 5 out of 6 didn't even pass.
Fordfreak4life to answer your question no the battery light wasn't on while driving. One day was starting fine the next day truck started turning over slow while trying to start it and then no start just click click click.
Is it your original alt? Have you pulled it and had it checked????
I'm guessing alt. Although new batteries CAN go bad in 5 months i have a hunch its the alt. Hopefully its something cheaper, and the alt didn't kill your new batteries. Just went through this, and my cheepy autozone alt killed a fairly new interstate battery:doh:
If you haven't already, pull the alt and get it tested. 3 bolts, 2 connectors, and a pull on the belt from the drivers side wheel well towards body and if you reach down under the idle tensioner there should be a spring loaded spring lock, which makes holding that belt loose and replacing the alt a cinch! Good luck..
Yes, sorry! Passengers side.
When you pull the alt and replace it, make sure that you plug in both your batts to a charger and fully charge them before you put the new alt on. What you will do if your batts arnt charge is overwork that alt and I have seen some go bad just because of that. If you are fully charged then you should have no prob. And charge the batts individually one by one not at the same time
1 - 18 of 18 Posts
