1 - 10 of 10 Posts
How do I tell if my 2011 Lariat, Has TPMS sensors.
Ordered new Wheels and Tires online. Should have the lift done this weeks but cannot tell if I have sensors. My guess yes?
Thanks
Super Sparky
It does, all 2011's have them. They became mandatory by the Feds back in late 2008.
Black Gold
i wouldnt worry about it, they are universal. just involves removing valve steam out of stocks and putting them in ur aftermarkets
Super Sparky
Check your wheels, you may have the band style. I know when they first became standard on our trucks, they were all band style. Look at your valve stems, you'll be able to tell which kind you have on your truck. I have mine turned off through my H&S tuner.
fine69, My local ford dealer part dept told me I had band straps. I have the valve style.
Thanks
Can you turn mine off??
The dealer set mine at 40 psi when i changed tires if they go below 40 psi the will set the light off. They can set it at what ever pressure you want
1 - 10 of 10 Posts
