1 - 5 of 5 Posts
Got a hookup for a King Pin D60 for pretty much nothing. Would it be worth swapping it into my truck that already has a Ball Joint D60
OBS junkie
Anything wrong with your Dana 60? Do you eat through ball joints or go wheeling/crawling with it? If the the answer is no, then I'd pass on swapping it in. If you can get it cheap, buy it, then turn around & sell it.
Wouldn't be worth the trouble. Do a little searching on the net and you will see quite a bit of the issues is just hype.
Sell it and then upgrade your suspension to a RS kit with SD springs. D60 can go for $$$ on Pirate.
1 - 5 of 5 Posts
