1 - 7 of 7 Posts
Are any of you running a kc38r on a stock truck? The new 366 one not the older one. I am wondering how one behaves on stock sticks but the .84 ar exaust housing. I am getting bigger injectors in the future but will be on stock injectors for a little while. I currently have the stock turbo with the 1.0 ar housin so im wondering what it would be like compaired to that. Im hoping lag would be compairable and not worse until i get bigger injectors. And for anyone that has the kc38r what size injectors are you using and how do you like it? any problems?
College Student
I have the kc38r with a 1.0 ar with baby swamps injectors. I want to say they are like 150cc off the top of my head. They are on the small side of the turbo. It does spool faster, but not by much. Pretty comparable to the stock turbo and injectors. When I set my ts6 to stock, it takes quite a while to spool. But with a 0.84 ar housing, it would be better. I wish I had the 0.84 instead of the 1.0 housing. I would recommend like 175cc or above.
Others on here would be able to point out the better injector recommendations than me. Just the 150cc is on the small side for the turbo.
Thanks man I appriciate the answer. How do you like the turbo so far? How are your temps towing? I will be getting the .84 ar housing and im coming from a 1.o ar on a stock turbo so im thinking it will be better.
College Student
Its pretty nice. As for dropping temps, it did a little, but it also flows more air, so it makes about the same boost wise, but there is a higher volume. The turbo is quieter in the cab, but has a pretty nice whistle out the exhaust.
Thanks for the input I appreciate it. did you install yourself? What up pipes did you use?
College Student
Tried to swap it myself, didnt work first two attempts at getting the rear bolts broke loose, just ended up braking tools. Was under the impression that it was pretty impossible to do on my 95. Ended up running out of time to do it and took it to a shop to have it done. Even then with their experience, it took them like 4 or 5 hours to get it pulled and swapped. They broke one of the studs on the collector and took some time to fix that. I had up pipes replace, but not sure what manufacture of them.
It doesn't look like a bad job if bolts cooperate with you.
I will be doing the job myself I know my way around a truck. Thanks for all the input! Anyone else have experience with this turbo? Or know of anyone running it on stock injectors?
1 - 7 of 7 Posts
