1 - 15 of 15 Posts
I just put new injectors and a itp regulated return with fuel bowl delete in my truck and now it runs like it has a miss and i have a kam error code. What do i do. please help. everything thats on my truck and what my truck is in my sig
PSA
subscribed...i didnt change anything on mine but it just started doing the same thing with the same code
The miss is probably some air that is still in the fuel lines. And a KAM (keep alive memory) error is because you pulled the batteries and them off for a while.
Discussion Starter · #4 ·
i never had that code before though. this is the second time i changed injectors
PSA
does it do it right away as soon as you start it?
for me, i can run for like 15 minutes, turn it off and when i start it again, its missing
Discussion Starter · #7 ·
it does it all the time hot cold doesn't matter
RDRCM
Has nothing to do with injectors or the "miss" you're describing. As stated it is KAM (keep alaive memory) for the PCM. You get this code from running a programmer, a chip, or removing batteires.
Discussion Starter · #9 ·
so if its from the chip y did it start sence the injectors and the regulated return ?
Discussion Starter · #11 ·
i went about 2 miles and i cant get it to go anymore runs horible
Work in progress
I dont think your code has anything to do with your problem. Clear it and see if it comes back.
Does it smoke at all? I was just thinking maybe one of the injectors didnt get seated all the way. Did you put a straight edge across to make sure? Just throwing ideas out there. Maybe a couple arnt firing?
All done now
With only 2 miles, you probably still have air in the system. Let it run for a while.
Discussion Starter · #14 ·
well i found the problem, i found the under valve cover harness on the driver side was unclipped just a Little and lost connection checked all plugs put it back together no code and runs good
1 - 15 of 15 Posts
