1 - 10 of 10 Posts
i live in CT and it gets pretty cold here in the winter, can i leave the block heater plugged in all night? or is that bad. i also go to my uncles house in VT and it is as far up before canada as it gets.
ya when it gets cold, i just leave it plugged in. it may sit for days before i drive it. but when i need it, it's ready
original "REZNECK"
like they said above plug it in with a good xstension cord shorter the better and use a gfi plug in.
All done now
Ground fault interupt. Really fast circuit breaker.
Bigfoot is an OBS
GFCI
Ground Fault, Circuit Interrupter.
It measures the current throught the hot and return wires, and if the currents don't match up very closely (as in a short to the ground wire, or short through you) it cuts them both off to prevent injury.
1 - 10 of 10 Posts
