1 - 5 of 5 Posts
was just at my local ford dealer looking at a 2006 F-250 crew cab lariat with the 6.0 diesel. drove it for a fairly long test drive and the only issue is the check engine light is on, they told me they will fix that problem as well as a complete detail, used car inspection and oil change and a full tank of diesel fuel. told them the only way i will buy it is they actually fix the check engine light issue along with the detail and used car inspection and oil change and a full tank of diesel, and good quality diesel at that. got it all in writeing and ended up purchasing it..... should be picking it up in a couple days. what should i be thinking about doing to it to make it trouble free
they call me tater salad
delete delete delete! then the norm exhaust intake gauges, tuner and you should be happy with it for a long time
Resident Idiot
Return it to the dealer!!! Just kidding just do a simple search on here an you will find lots of info. EGR delete, coolant bypass filter, coolant flush, maintenance on time with ford filters, ect ect ect
1 - 5 of 5 Posts
