Will you be going?
  • Total voters
    4
1 - 16 of 16 Posts
After talking to Lloyd from Mid Atlantic Diesel Performance for a little bit. We have figured that the July 25th meet will be for all makes and models of diesels. Cummins, powerstroke, duramax. So tell your buddys.
It will start at 9am. It will go until we see fit to end it.
$75 for 3 pulls.
Here are the only things Lloyd asks of you if you dyno your truck.
-Dually trucks will need to remove the outer tires
-Stack trucks will need to drop the exhaust underneath so we can hook up the flex pipe
-If anyone has a Dmax coming, they will need to remove the plate under the front of the truck so we can get a tach sensor reading.
If you have any question please pm me.
NOTE If you are on multiple fourms that i post this on. Please only vote once. Do not vote on every fourm.
The Unseen Mod
Damn my meet is the 24th sounds like a busy weekend.
I might be there. I might try to get a oil pump by then and I might dyno but not 100%.
Is anyone going to this? If so I'll try to swing by.
I've delt with Lloyd a few times, he needs to hire someone to answer his phone!
I might try to make it down.
1 - 16 of 16 Posts
