There I was . . . pulled out the old one and looked it over. Looked at the new one. Compared the push rods - the new one was smaller! I hemmed and hawed and the damage on the old wasn't as bad as it looks in the pic, so I decided to keep the old one.
Cut the end off the push rod, dremeled it smooth. Tried to fit the replacement part. Mmmm no. Used a filed, and the dremel . . . hmmm. Time to grab the calipers.
Mind you, the clutch master cylinder is still connected through all this.
Pull out the trusty calipers, and the push rod end is .3996 inches in diameter.
The part is .3765 in diameter. Oh, f***.
Here come the drill bits. Of course I don't have one between .390 and .409.
Anyway, the part is on. It's going together smoothly. It's Carhartts insulated coveralls in the morning and regular coveralls this afternoon. Except the $%^&*() master cylinder will not twist the 45° it needs to go into the clutch support bracket. It is square, and if you twist it 45°, it will be square to the bracket and slide into place, and then twist back and lock in place. Arthritis is a incredible handicap.
Break time for an adult beverage, and back to trying to install it.
