3561 - 3578 of 3578 Posts
Discussion Starter · #3,561 ·
They made in china
You did flush all hoses and components separately and in reverse flow direction, right?
Air only. However, it ran for all those 1700 round-trips for six months, so I don't believe it was left-over debris.
I believe "cheap Chinese crap".
  • Like
Reactions: heavydoc
PSN intsigator
Possible, but all it takes is 1 piece of trash to make many more. If you dont have flush some brake cleaner works to, I've used it myself. Just make sure to blow lots of air through it in reverse flow, and vacuum the system down for atleast 30 minutes 1 hour is better
  • Like
Reactions: Jax
Discussion Starter · #3,563 ·
Here's a new one for you . . . We departed the RV park, and my brakes vibrated. However, the longer we drove, the less it did it.
I thought that was indicative of a warped rotor, but that wouldn't fade away, right?
Discussion Starter · #3,565 ·
Any idea of what might cause the "shudder" feel in the brakes?
don't play well w others
Abs motor maybe. Kinda like a emergency stop. You feel it in the pedal, the brakes don't actually shudder. Could be a speed sensor. Pull some codes when you get a chance
  • Like
Reactions: Jax
Discussion Starter · #3,567 ·
Already did (through the Edge CST2) - nothing abnormal.
Probably a piece of rust on a sensor
It is magnetic pickup.
Cleaned itself off. I'd just keep going and see if you have any more issues
  • Like
Reactions: Jax
2001 Lariat F350. Leveled, 5” exhaust, ww38, 6637,
I’ve had that happen with the CPS. Only instead of rust it looked like a piece of cast on it.
Changed it anyways so I had a known good sensor in my glove box.
Discussion Starter · #3,570 ·
All A/C components flushed and replaced. Works well
Discussion Starter · #3,571 ·
Now --- Best after-market bumpers? I don't want one of those huge black ones. Ideas?
I have always had good luck with keystone if stock. If you want to build a bumper check out move
Discussion Starter · #3,573 ·
Thanks - I looked at move - I don't need that extra foot added to an already long truck.
I'll check out Keystone.
Discussion Starter · #3,574 ·
Damn. Chrome bumpers are discontinued. :(
Discussion Starter · #3,575 ·
NEW QUESTION: Do you have to take the rear cone off of the zf6-650 manual transmission to replace the rear output seal?
Discussion Starter · #3,577 ·
Anyone? Bueller?
I don't think think so, just the "flange."
On the bumpers, if you can weld, look at the diy kits. Everything is precut. Some bending required, then weld'er up.
Sent from my SM-G988U using Tapatalk
  • Like
Reactions: Jax
