3541 - 3560 of 3578 Posts
Discussion Starter · #3,543 ·
Well kiss my rabbit!! I never expected to find this. Every component in the system changed out except the lines and the evaporator.
Wood Gas Cylinder Musical instrument Metal
Discussion Starter · #3,545 ·
And it is freezing still. I hope like hell the new compressor isn't breaking down.
PSN intsigator
Evap freezing? Either you don't have the air flow through it, bad freeze switch or wrong amount of freon in the system
Discussion Starter · #3,547 ·
I am not sure if the evaporater is freezing. If it is, I have to take apart everything in the bottom.
I did put in an auto adjusting orifice. It doesn't seem to stay frozen.
PSN intsigator
So what is freezing?
Discussion Starter · #3,549 ·
The only visual I have is the coat of frost on the accumulator and the lines to the evaporator.
The other sign is that less and less air flows from the vents until there is next to nothing.
However, I haven't had time to give it a good test, yet. I drove the Tundra to Tucson since she hasn't had a good run lately.
PSN intsigator
Is there water still dripping from the evap drain. I'm betting your freeze switch is bad
Discussion Starter · #3,551 ·
Freeze switch? Is that the one one that screws into the accumulator? It's new.
PSN intsigator
No, the freeze switch is in the evaporator fins and tells the compressor to turn off to keep it from freezing. The one on your accumulator is a high low pressure switch
Discussion Starter · #3,553 ·
Okay, how do I get to the evaporator. From what I see, I have to take everything off from under the dash. :(
PSN intsigator
Ya, it is a pain! But you should be able to find a 2 wire probe. When evap is freezing it should have no continuity and when it is not freezing it will have continuity
  • Like
Reactions: Jax
Discussion Starter · #3,555 ·
Thanks! That will be next on my list.
Discussion Starter · #3,556 ·
End result- the orifice tube was blocked by crap and freezing up the system.
Please understand, my AC guy and I have been working by the book .... but ... the compressor died after everything was working marvelously.
So, I was okay putting on another dryer and tube.
Now, it is feeling up again... the failed compressor means it needs a flush.
Given y'alls input. I didn't want to, but he said the failure point was people not purging the solvent for 45 minutes.
So, I will do this again. Research backs up his statement, as does the piece of leaf matching the previous one. Flushing for the win!
This was last time, but it froze up by two hours again.
  • Like
Reactions: JustAFenceBuilder
Discussion Starter · #3,557 ·
Well, I thought it was the garbage from the original compressor failing that was mucking up the works.
Today, The compressor seized up on it.
What the Hades is with the @$$^& parts these days? 🤬
PSN intsigator
They made in china
don't play well w others
All that crap was still in your hoses. The compressor is rotory
No room for all that crap. Came to a screeching halt
PSN intsigator
You did flush all hoses and components separately and in reverse flow direction, right?
