3421 - 3440 of 3481 Posts
don't play well w others
Not sure on zf6. Zf5 is a different case goes to the transfer case adapter and case. The co.puter is different. Pedals are different. Wiring harness is different......drive shafts are different...
I am fighting that battle on one of my builds manual to automatic
It's a lot to figure out
Administrator
manual it automatic is a biatch. auto to manual is a lot easier. just jump the neutral safety switch, move the reverse wires to the switch in the trans, and get a 4X4 trans. the computer will think the trans is in neutral and engine will run like normal.
2001 Lariat F350. Leveled, 5” exhaust, ww38, 6637,
Will you still have Cruise control?
Discussion Starter · #3,426 · (Edited)
Guy that owned it says it has a 5R100 Transmission. Thoughts on that?
Of course, he thought he bought it in 2000, but it was exported to Canada from the factory. It came down to the US in 2002 and he bought it August 2002, says Carfax.
His wife has a better memory.
Discussion Starter · #3,428 ·
  • Like
Reactions: JustAFenceBuilder
Discussion Starter · #3,429 ·
Ouch. This thread says no . . .
I have a 5r100 in my 06 e450. Love it. Great transmission. Tow haul is bad azz on those.
I think they started in 06 tho, not sure.
I forgot about the hump in the floor for the zf. That has to be there. You won't get a zf in a automatic truck. It sits 5" higher than an automatic.
Tom and I have another friend put a zf5 and bw 4407 transfer case in a 67 truck. He not only had to butcher the cab, but took a big chunk out of the frame too
  • Like
Reactions: Jax
Hardon for manuals.
Keep the 4x4 a auto, keep the truck you have, sell the toyota
Discussion Starter · #3,434 ·
Yeah, but that foot long 3 speed was bullet proof. Especially when compared to modern stuff.
Maybe I'm missing the point, but why take 2 running trucks apart? Did I miss something?
Because I built the engine in one truck (99)! I really wanted a crew cab but could not find one over two years looking. The 00 4x4 is a plus. The lift kit on the 4 x 4 is not. I don't like lift kits. The axles are the issue, not the body.
The 00's engine has near 300k miles.
Discussion Starter · #3,435 ·
So, if I swap engines, I can rebuilt the 00 . . . or just pull the 00 and not use it. . .
Keep them all. Never can have too many trucks!
Sure. Truck stop special
