2161 - 2180 of 2187 Posts
Discussion Starter #2,161
It's only one bolt and it's in the middle of the axle on top. Should be easy peasy. Most likely it just has metal on it.
I saw that the 2000 has that, but the 1999 supposedly has them in the hub? Too busy researching to crawl under yet . . . .
Administrator
Agreed. remove the sensor, clean it good, and reinstall.
Discussion Starter #2,163
Thanks so much, Shawn! Yes, it is on the rear differential.
Discussion Starter #2,164
Sigh. I haven't kicked my lazy ass out there to fix anything. And I have new3 2shot . . .
Shocks. ^^^ That was kitten Inkspot helping. . . .
PSN intsigator
Don't feel bad I've got new shocks waiting for me for the Excursion and my 02.
  • Like
Reactions: Jax
don't play well w others
Ya'll old farts need to get out there and get something done.
Like doc and his tree work.
PSN intsigator
Hey! it worked more gooder... at first
  • Like
Reactions: tjctransport
PSN intsigator
And I'm still waiting for the engine rebuild kit. The cylinder head parts should be here tomorrow
Bought some blue zip ties for the plow truck because I know how much you love them doc
PSN intsigator
Self trimming on the tailpipe.....
Discussion Starter #2,172
Did a general bolt-tightening on the underside of the power train, and put in new rear shocks. Dang, compressing those things was hard! But now I'm putting off the front shocks for tomorrow.
202658
@heavydoc -- Your turn!
  • Like
Reactions: BBslider001
I just use ratchet straps to compress shocks anymore
Sent from my SM-J737V using Tapatalk
PSN intsigator
I put a jack under the hitch and start raising to take some preload off of the suspension. You only have to compress the shock a little bit that way
  • Like
Reactions: Jax
Discussion Starter #2,175
Thank you!
Discussion Starter #2,176
OMG!!! It took me as long to do one front shock as it did for me to do two rear shocks! What a royal PITA!
HELP! The Bilstein 4600's have a 6mm hex on the bolt end, and you have to tighten down a lock-nut. What do you guys use? I can hardly get my hands in there!
202676
The old shocks may have been the originals. Wow. Should have seen the "welded-on rubber" on the lower shock mount.
  • Like
Discussion Starter #2,177
And I just figured out the 4x4s do not have the front mounts as the 2 x 4s.
Deep socket on a flez ratchet. Hold the shock with your hand.
Ball joints on 4x4 are easier, so it makes up for it later......
  • Like
Reactions: Jax
Discussion Starter #2,179 (Edited)
New shocks in. The Beast rides like a dream!
I really like this truck. Not many people can say that about a Found On Road Dead Basket Case. But this one has revived spectacularly!
Now you know why I'm so found of my old kicked to the curb rebuilds !!!
  • Like
Reactions: Jax
