1881 - 1900 of 1989 Posts
Discussion Starter #1,881
I still am not sure that something isn't right - once warm, the steady 666 rpm fluctuates from 640 to 680. Yes, a lot less swing, to be sure, but I still wonder. Of course, there is probably air in the oil rails.
I changed the fuel filter and will watch it like a hawk. In the meantime, I will use up fuel and drop the tank probably by the end of next month.
PSN intsigator
I wouldn't want nothing in relation to 666, just sayin!
Discussion Starter #1,884
Ha! I'm riding State Route 666 up N. AZ with a bunch of Legion Riders this weekend!
Discussion Starter #1,886
It will be! Temps over 100 every day this week, on a road full of hairpin turns. Fun, but a little challenging.
don't play well w others
She was/is in the army... pretty sure she can teach you some new words.... and then there are sailors :p
Maybe you should correct someone you know. NOT ME> You took that out of context. If you want to pick on a member, probably I am a bad choice. Cheers, have a good day. You get a pass for this one.
Discussion Starter #1,890
Hiya, @Toybreaker !
Today's fun . . . Need to have the AC dryer and filter changed. Took it back to the guy who did the recharge since he didn't charge much.
The ol' biotch was in high form! Could not break the dryer's nut loose. He has serious tools and it just wasn't budging. He ended up splitting the nut. He said someone had probably used the compressor oil on the threads and due to its acidic nature, it crystallized and stuck the fittings like glue!
201624
And . . . the orifice filter was as bad as I thought it would be . . . That brown spot is what is left of a leaf that was in there. OMG.. . . .
201625
Never ending surprises in that truck. I can't believe one person could abuse a truck that much
  • Like
Reactions: Jax
Resident Curmudgeon
I did the A/C "rebuild" on mine back in 2014. compressor, condenser, receiver/dryer and orifice tube....... Still blows ICE cold....
Tell ya something, I miss Az.... especially the winters.... But that dry heat sure beats this nasty arse humidity, along with the east coast air force (mosquitoes....)
Loved going out after dark to see the saguaros in bloom and watch the bats feed on the flower nectar...
Discussion Starter #1,894
During migration season, I leave my hummingbird feeders out and the bats feed from them. You can sit quietly on the porch and watch them come in. :)
  • Like
Reactions: Toybreaker
Discussion Starter #1,895
I look at it as, the truck survived that (those) abusive owner(s), so it is definitely tough! I expect to get at least a half-million miles out of it.
Administrator
both Charlie and I are members of the half million mile club. his 89 F350 with 300 six cylinder, and my 88 F-SuperDuty 4X4 pickup conversion with 7.3 diesel.
My 89 will soon to be a superduty conversion.........
Shhhhhhhh.
Dont tell anyone..........
Discussion Starter #1,898
Shhhhhhhh.
What makes a Superduty a Superduty? I thought they just applied the name one year . . . .
Discussion Starter #1,899
Like this -
What “Super Duty” Means
“Super Duty” is simply a way to distinguish these trucks from the base model in the Ford Series: the F-150. Not only that, but the bodywork and chassis are both different from the F-150 as well simply because these are bigger trucks.
Why is it important to distinguish the F-250 and F-350 from the F-150? Because, these trucks are built for a tougher kind of job. Where the F-150 isn’t enough, turn to a Super Duty.
The chassis and suspension components are no joke; and much stronger than the ones found on the F-150. This allows for higher payload and towing capacities for larger projects. On top of that, the PowerStroke diesel engines are available as an option for those who need the extra kick where torque is concerned. Even the transmission is a heavy-duty setup.
The origional superduty came out in 87. Was a f 450 and wore the regular pickup cab. They had straight axle, and springs on the front like the big trucks starting at f 600.
Then in 99 Superduty became it's own line from f 250 -f550.
The cabs, frame and beds were different than the f 150 and f 250 light duty
