861 - 880 of 1109 Posts
don't play well w others
You can turn either way either engine. The valves open, and close.
If you cant turn it over by hand with the plugs or glow plugs in, something else is wrong
Discussion Starter #862
Dude, you must be super strong. When that piston hits top dead center with both valves closed, that is a lot of pressure to overcome!
Discussion Starter #863
So, what goes in those holes covered with yellow tape?
I had my wife turn over the 4.9 with a breaker bar on the f 350 when I was trying to get the frozen clutch unbolted. I was holding the transmission from turning with it. She owns an operated a towing/ scraping business, but isn't the hulk.
Idk.
I never had any trouble. Sometimes to find tdc, you have to turn them over by hand
I would have to go down and get a pic in the morning. Raining, and almost dark now.
Probably too far away to see in this pic
Jax, Do not put those fuel line brackets back on!!! Remove and throw them away!! You don’t need them. These will eventually cause a pin hole leak in the line over time and vibration and leave you stranded in the middle of nowhere! Hope you have AAA. Happened to me.
PSN intsigator
The front one by the fuel filter is the ICP sensor. The other 2 are plugs. And definitely throw the fuel line brackets out. If you worried about them rubbing on something shove a piece of fuel line over them
Sent from my SM-N975U using Tapatalk
Discussion Starter #868
I noticed how it rubbed. I wrapped friction tape under the bracket. I will happily remove it.
Discussion Starter #869
ICP = Injection Control Pressure?
The shop put plugs where they are supposed to be. I am guessing the Oil Pressure sensor goes in one -- which one?
And is this right for the oil pressure switch location?
201032
Discussion Starter #870
I cannot even tell where this Engine Oil Temperature sensor goes.
201033
Discussion Starter #871
I face a two-day + delay every time I have to order parts. I still need the donut gasket from the exhaust manifold to the up-pipes, right?
Discussion Starter #872
It sure is true that you spend 90% of your time on the last 10%. :rolleyes:
Discussion Starter #873
Well, dang it, had to order more bolts. smh
Discussion Starter #874 (Edited)
aaarrrggghhhh!!!! What on Earth is a "Air Inlet Duct Tube mounting bracket"????
201035
Is it the bracket thing in this parts picture?
201036
If so, where does it go? the picture is $%^&*( useless!
Jax,
It is universal common knowledge don't ya know ;) (it's like my forklift... everyone needs a forklift). I would hazard that you are at the point of mounting the turbo and intake. The bracket at the top center of your picture is what supports the intake tubes so I would think that is the one being referenced.
Cj
Discussion Starter #876
Thanks, CJ!
I also found what looks like the bracket in @heavydoc 's engine picture. If so, it should go something like the below. Question - does it mount on the valve cover stud bolts? If so, which ones?
201037
Discussion Starter #877 (Edited)
Is that on the passenger side frame rail
Hi! @heavydoc This was the two wires, primary yellow, one with black stripe and one with red stripe.
It goes to a socket and yes, I believe that is the passenger side frame rail. Do you know what it is?
Jax,
On my 97 it attaches to the upper front valve cover bolts.. I think you could put your turbo in place and verify.
201038
Discussion Starter #879
Discussion Starter #880
Another question - Which sensor is this?
201039
