1621 - 1640 of 1652 Posts
· Premium Member
99 & 00, F350s, manual and auto, Ext & Crew Cab, 4x2 & 4x4, need more room!
Discussion Starter · #1,621 ·
I've never seen a gasket-maker not stick before. I threw that tube in the trash.
  • Like
Reactions: 1970something
· Premium Member
Discussion Starter · #1,622 · (Edited)
EDIT -- OOOPS! This is about the Beast, not the Pig.
Back to the engine. Ever since it turned cold, I have noticed a light blue-gray smoke from the exhaust. It seems to go away once the engine is warmed up.
Could that injector be causing it, or is something else going on?
· Premium Member
Discussion Starter · #1,624 ·
Okay, Back to the Pig!
I am getting this code recently. I have a deleted pedestal but also the RiffRaff link to stop this code. Why would it show up again?
What are the Possible Causes of the Code P0476?
  • Faulty Exhaust Back Pressure Valve
  • Exhaust Back Pressure Valve harness is open or shorted
  • Exhaust Back Pressure Valve circuit poor electrical connection
· Premium Member
Discussion Starter · #1,627 · (Edited)
I now remember why I don't like FTE as much. The put all their 1999-2016 and gas and diesel in one forum. Hard to find anything.
· Premium Member
Discussion Starter · #1,628 ·
Working on the 00 Pig yesterday, rear brakes. I bought all the high-end stuff last year. Did not have the rear axle inside bearings.
Ingredient Amber Cuisine Font Circle
Managed to find one in town. The other arrives in the morning.
Good call to plan to buy them all, if I had bought them ALL. The bearings - under hand pressure - felt like they had rumble strips inside.
New PowerBrake Calipers, Rotors, parking brake shoes and hardware.
Right rear Axle seal had been seeping.
· Premium Member
Discussion Starter · #1,629 ·
Pig has new brakes all around. Parking brake is way hard to push. I sure hope that breaks in.
  • Like
Reactions: JustAFenceBuilder
· Registered
Jax,
If you seal were seeping... check the axle vent tube for blockages. On my old 87 I had to replace the seals a couple of times because they kept "failing." When they failed a third time I took a close look at the axle... and discovered that a mud wasp had made a home in the vent line. As the axle got hot the pressure inside would build and force oil out though the wheel seals. Once I removed the nest the seals stopped having problems.
Cj
  • Like
Reactions: Jax
· Premium Member
Discussion Starter · #1,632 ·
did you check your cables for free movement before assembling?
Yes. TBH -- I took it over to a retired Fire Dept mechanic's place -- he has fancy tools and experience I lack.
Which was a good thing, because the obstinate biotch (the truck, not me) stubbornly made every step take forever . . . as well as the missing bearing I didn't have. It's good to have friends.
  • Like
· Premium Member
Discussion Starter · #1,633 ·
Hey, how can you tell if your truck defuels? What does it do?
· Premium Member
Discussion Starter · #1,635 ·
I was towing up a hill @ 55mph and the load went to 100%. A few hundred yards later, it lost all power and slowed to 35mph Is that defueling?
· Premium Member
Discussion Starter · #1,637 ·
I didn't notice. :(
· Premium Member
Discussion Starter · #1,639 ·
Hi, all!
Another National Park in the books! White Sands, NM.
I am going to install a boost fooler on the 00 Pig. F'r defueled on me 6 times!
  • Like
· Administrator
i made my own. small air pressure regulator from harbor freight set to 19 psi. two small brass nipples, two small hose clamps. cut the map sensor line and stuck it in there.
total cost was under $15 15 years ago when i got the 02.
