1581 - 1600 of 1652 Posts
· Premium Member
99 & 00, F350s, manual and auto, Ext & Crew Cab, 4x2 & 4x4, need more room!
Discussion Starter · #1,581 · (Edited)
I am seeing torque specs from 18 ft-lb to 24 ft-lb. smh
Book says 18ft-lb / 24Nm.
· Premium Member
Discussion Starter · #1,582 ·
Finally got that stuck biotch apart. The O-rings are squared off. . . . I wonder if they are original?
Looks a LOT better than the Beast's oil cooler. Passages for water are clear, and I don't find anything in the oil area. A good cleanup tomorrow - after it has all night to drain, pissy little monster. Then put it together and back in the truck.
Gave it all night to drain and it still pissed all over.
I don't know why I changed the seals. Crack half way through doesn't mean it's broken!
I tried to cut the inside (green) seals off but the gasket was too hard for the utility knife. Fortunately, they broke off when I used a screwdriver. Hard as a rock!
Now to mount it back.
· Premium Member
Discussion Starter · #1,583 ·
Question - the Pig has gold antifreeze. I see corrosion around the openings. Is that worrisome?
· Premium Member
Discussion Starter · #1,585 · (Edited)
Thanks, Tom!
Tool Gas Auto part Pneumatic tool Metal
Dang thing went back in so easily, now I'm worrying myself to death wondering what I did wrong! Took only 30 minutes including the antifreeze and remounting the wheel.
But darn it, the ABS sensor is here. One more thing to do . . . .
  • Haha
Reactions: 1970something
· Premium Member
Discussion Starter · #1,586 ·
ABS sensor in. Can't even test it until the PCMs come back. Sigh.
Might as well take a nap.
  • Like
· Premium Member
Discussion Starter · #1,588 ·
Stupid Commiefornia storm is keeping up a steady rain, and my PCMs are supposed to be in today. I won't even be able to install them given this mess.
· Premium Member
Discussion Starter · #1,590 · (Edited)
PCMs came in, and after I installed the Beast's, I got the Pig's in.
Crank, no start. Crank, no start. Crank, no start.
How freaking long does it take to fill an oil cooler!
In between, while letting the starter cool, I was adding oil and water to the coolant.
Fourth try, she fired like nothing had ever happened. Need to wash both engines but I don't think they are leaking.
Still throwing the C1145 Front Right ABS sensor code, though. I guess I get to play chase the wiring.
· Premium Member
Discussion Starter · #1,591 ·
F*, F*, F****
(OK) [09:38:42.356] KOEO Injector Electrical Self Test has been started
(OK) [09:38:58.160] Test completed successfully, no errors found
(OK) [09:39:11.721] KOEO Output State Self Test has been started
(WARN) [09:41:19.353] Test completed, found DTCs: P1395, P1396, P1397, P0380, P1141, P0381, P1140, P1748, P1536, P1464, P0230, P0231, P0220, P0475, P0232, P0460, P0603
(OK) [09:42:13.142] KOER Switch Self Test has been started
(WARN) [09:42:35.453] Test completed, found DTCs: P1780
(OK) [09:42:52.979] KOER Cylinder Contribution Self Test has been started
(WARN) [09:43:02.137] Test completed, found DTCs: P1464
(OK) [09:43:23.709] Key On Engine Running On Demand Self-Test has been started
(WARN) [09:44:42.681] Test completed, found DTCs: P0476, P0541
(OK) [09:45:18.422] Key On Engine Off On Demand Self-Test has been started
(WARN) [09:45:30.619] Test completed, found DTCs: P0605
(OK) [09:45:50.059] PCM Output Test Mode (OTM) has been started
(OK) [09:46:01.049] PCM Output Test Mode (OTM) has been started
(OK) [09:46:17.212] Read system monitor status has been started
(OK) [09:46:17.236] Malfunction Indicator Lamp (MIL) Status: Off
(OK) [09:46:17.237] Misfire monitoring: Complete
(WARN) [09:46:17.238] Fuel system monitoring: Not supported
(WARN) [09:46:17.238] Comprehensive component monitoring: Not supported
(WARN) [09:46:17.239] Catalyst monitoring : Not supported
(WARN) [09:46:17.240] Heated catalyst monitoring : Not supported
(WARN) [09:46:17.241] Evaporative system monitoring: Not supported
(WARN) [09:46:17.242] Secondary air system monitoring: Not supported
(WARN) [09:46:17.243] A/C system refrigerant monitoring: Not supported
(WARN) [09:46:17.244] Oxygen sensor monitoring: Not supported
(WARN) [09:46:17.245] Oxygen sensor heater monitoring: Not supported
(WARN) [09:46:17.246] EGR system monitoring: Not supported
(OK) [09:46:20.179] Test completed successfully, no errors found
(OK) [09:46:33.500] On Demand Self-Test has been started
(OK) [09:46:38.170] Test completed successfully, no errors found
(OK) [09:46:56.306] On Demand Self-Test has been started
(WARN) [09:46:59.996] Test completed, found DTCs: C1446, B1575, B1462
(OK) [09:47:22.890] On Demand Self-Test has been started
(WARN) [09:47:29.322] Test completed, found DTCs: C1145
· Premium Member
Discussion Starter · #1,592 ·
Hmmmmm :cautious: I may have fouled up the test for the KOEO.
· Premium Member
Discussion Starter · #1,593 ·
I guess I will go out, clear the codes, and try again. Sigh.
· Premium Member
Discussion Starter · #1,594 ·
Oh, yeah. Note to self. Make sure your foot is all the way off the throttle before clicking "OK" on the KOEO tests.
  • Like
· Premium Member
Discussion Starter · #1,595 ·
Only code now is the C1145.
· Premium Member
Discussion Starter · #1,597 ·
Flubber foot. Can't blame anyone else for me.
  • Like
· Premium Member
Discussion Starter · #1,599 ·
Hell, yeah! Any thing is good to razz another over!
