Body module is taking a poo.
Doc had the same issue on his excursion
Body modules - as in the GEM?Body module is taking a poo.
Both? So I should track the wiring from front door through middle pillar to inside rear door?ahhhh. you did not say rear door. they are known for the trigger wire breaking and shorting out inside the door loom between door and B pillar.
Did not take the cover off the center piller, between the front and rear door, but did remove the rear door cover (because maintenance. Lock and window dragged. Now clean and lubed.)ahhhh. you did not say rear door. they are known for the trigger wire breaking and shorting out inside the door loom between door and B pillar.
Black with white streak. And the wires look really good. At $14 per switch, I am going to replace the two rear doors, as I have to take them apart and clean & lube them anyway. I suspect, though, the short is somewhere up front. 😪sorry, still a little under the weather and sleeping way too much.
if you can access the wires in the "accordion" wire looms between the door and pillar that is where they usually break.
i just don't remember what color wire to test.
No such thing! But it is important to start pushing yourself - walking short trips, often.sorry, still a little under the weather and sleeping way too much.
Of course 16-20 is okay, when you are getting over a severe illness.so 16-20 hours sleep per day is ok? i get by on 6-7 usually.
and i am doing plenty of short trips. the bathroom is 20 foot away downstairs, and if i am upstairs it is almost 45 foot away.
that means i am walking/stumbling between 40 and 90 foot every 2-3 hours!!! 😁
One of three Kracken, and one of six total cats. My Kracken are the foster fails.What a cutie!
Looks a lot like a cat my Mom had when I was little.
