According to the transmission I took out, that is definitely a hole.that sure do look like a hole to me.
I am so sad. I wanted to be able to keep this transmission so very badly. 😪
A friend on a social forum said I could fix that easily with photoshop.The cracks in the case worry me more than that.
Sounds reasonable.A friend on a social forum said I could fix that easily with photoshop.
I ran the news delete mod in my life about 3 years ago. One of the best things I’ve ever done.Sounds reasonable.
Think photoshop would work on the news also?
Sorry late to the answer to your questionDamn, you guys are GOOOD! Thank you so much!
I had to enlarge it amazingly to see that switch crack and smash.
However, the truck would not start with the key. It did start with the key on and jumped from the solenoid on the fender. Also, the transmission is reporting "4th gear" to the Edge device.
Funny thing is, I never expect the switch on the driver's side. So, I have a FoMoCo switch here.
I have to talk to them on the phone.![]()
Whats the wait time on a new one?Basically, the Pan leaks. The impact on the Range Sensor Switch may have "rolled" the lip of the pan. Also, the drain plug area was dented into the pan and leaks.
I could wait for them to build me a new one, or let them send me a pan to replace it. I have asked them for an extended warranty given the evidence it was dropped. I don't want to be an arse, and don't believe that getting a whole 'nother xmsn will do anything for me.
Thoughts?
Thanks, Charlie! What is MLPS?
New Question - Does anyone know what the number on the case means?
The tranny from Dieselsite has a 24 on top, and a 24-2 on the bottom. Mine has a 51.
EDIT - Never mind, even Dieselsite doesn't know.
Manual lever position switch.I just don't understand why my Transmission Range Sensor Switch doesn't work.
