421 - 440 of 530 Posts
Discussion Starter · #421 ·
ford part number YC3Z-3A093-AB
new autoparts shows $433.69
fordpartsonsale shows $423.97
fordoempartsonline shows $427.86.
ORDER #4808 - Placed 08/29/2021
Hello Jacqueline Tregre,
This is to confirm that order #4808 has been canceled, and a refund of $473.24 has been processed. It may take 2-5 business days for the refund to reflect on your billing statement.
We appreciate your business, and hope you will shop with us again!
AutoNation Ford Littleton - 2233
(303) 738-4447 | [email protected]
  • Sad
Reactions: heavydoc
Hey Jax, have you tried calling around to some of the shops that install lift kits, maybe they have a stock one laying around?
Discussion Starter · #423 ·
A couple in Tucson, but I really need to make a list and go down it systematically.
Or . . . maybe one of them can fabricate it for me. :(
Discussion Starter · #424 · (Edited)
What if I were to use a 2" drop Leveling Track bar Bracket? The difference in angle is like 1°.
It would put the Track Bar more on plane with the axle.
I could put on an adjustable track bar, too. God, what a Frankenstein.
They recycle all the "waste" parts. :(
Discussion Starter · #425 ·
Another topic - I have dual steering damper shocks.
204736
The Bilstein seems like a bit much for this application:
204737
Should I put a pair of these back on?
204738
Administrator
you don't really need two.
my 04 don't have any on it.
the stock stabilizer got bent and removed. i never got around to putting the replacement back on. 45,000 mils now without it. but the whole front end is new and tight.
Discussion Starter · #427 ·
How does one bend a steering stabilizer?
Discussion Starter · #429 ·
Native Californian
tree stump, large rock, fire hydrant, municipal driver that does not care about the truck cause it ain't his.
Dicks....everywhere and just don't care.
  • Like
Reactions: 1970something
PSN intsigator
Build one out of thick wall tubing and Hine joints!
Discussion Starter · #432 ·
The 00 Pig is driving me mad!
All that work flushing the coolant, new reservoir, and it was fine, no leaks, no nothing. Then yesterday, while taking a picture of the steering shock, I saw coolant dripping steadily from the water pump.
Do these 7.3L actually develop an intermittent leak in the water pump? o_O
Discussion Starter · #435 ·
Discussion Starter · #436 ·
no one has commented on my idea of putting a 2" drop (leveling drop) track bar mount on it.
Problems? No idea?
don't play well w others
Problems? No idea?
Sending you the solution.
  • Like
Reactions: heavydoc and Jax
