1 - 13 of 13 Posts
so I got my new Torque App up & running and I've been playing around with it & it works good so I figured I'll plug it in & see what it says & well i got a lot of codes back.
ill list them & hopefully someone can help me out on this. I def. need the help
P32DF
U3F00
U3F78
U3FA5
P338A
P0093 Fuel Leak Problem
U3F24
P3715
U3F14
P09E8
P09BA
P3840
U0B81
P3B64
P018E
P00BD
P082A
P0208 Injector Circuit Cylinder 8
P0900
P00E0
P0080 Exhaust Valve Control Solenoid Circuit High (bank 1)
P0F01
P0F0c
P008A
P0011 "A" Camshaft Position Timing Over Advanced or System Performance (bank 1)
B1A44
P0B04
P0140 O2 Sensor Circuit no activity detected (bank 1 Sensor 2)
U10E4
U0000
P0400 Exhaust gas recirculation flow
P0018
P000C
P0300 Random/Multiple cylinder misfire detected
P0004
P0280 Cylinder 7 Injector circuit high
P0380 Glow Plug / heater circuit "A"
P0480 Cooling Fan Control Circuit
P0580
P0680
P0780 Shift
P0880
P0A80
P0B80
P2000 NOx Trap Efficiency below threshold Bank 1
P3130
P3374
P382E
P3A66
P3CF4
C0020
C0C44
P0189 Fuel Temperature sensor B circuit Intermittent
P00D3
P0010 "A" Camshaft position Actuator Circuit (Bank 1)
P2666 Fuel shutoff valve B Control Circuit Low
P018D
P0A28
That is every code that showed up.
My truck is modded.
E Fan.
E Fuel
Bigger Injectors
Bigger Exhaust
TW Tuned.
hopefully that helps you guys & hopefully you can help me figure this out as that is a lot of codes
Squeezing out Torque...
You know m j & I from the OBS Torque Pro thread?
Those codes aren't relevant to an OBS. The OBS extended PID's for the gauges are still a manual entry affair. Torque Pro is not there yet as a usable OBD scanner for OBS PSD's.
m j, I and others used Car Gauge Pro for those functions. It's only $5.95 for that app, works with the same ODB/BT adapter... and is opposite in functionality-- meaning it's strength is as an OBD scanner and not in displaying everyday use gauges... ...And Torque Pro's strength is in displaying everyday gauges, but not as an OBD scanner.
The author of Car Gauge Pro has his priority set on what it is strong at, not for use as an everyday gauge panel. He has no plans to do that, But, as a scanner- You can even do CCT's, Injector Buzz tests, etc. with that one.
Torque Pro has some functionality in both, both is not there for OBS PSD's as a scanner. Maybe some day, but not today.
For me, I see no problem using both. Cost is nominal having both compared to any standalone scanner... and being an OBS owner, you probably already know that few OBD scanners work with OBS PSD's.
so the injector # 8 and the misfires mean nothing pretty much? I figured those meant something at least but thanks. I'm gonna get car gauges pro here today
With all that it's reading wrong, mistakenly, that you do not have.... how do you trust that one or a few might be right? Better to re-scan it with one that does read it, to make sure, right?
Discussion Starter · #5 ·
Ok I got car gauges pro. But have no clue of how to make it work. It's not quite as user easy as the other one
Does this help?
Discussion Starter · #7 ·
Unless it has specific settings for Ford Enhanced, non-OBD-II, Enhanced Powertrain, it is NOT reading anything meaningful from your truck.
You are funny. I wouldn't have recommended it unless I knew it worked on my 'own 97 OBS PSD.
So yes it has Ford extended, wihich includes OBS PSD PID's, which as we know are unque to it... and are OBD specific, but not OBD-II.
Here is "m j" from here, doing a buzz test on his OBS:
Discussion Starter · #10 ·
so what does it do when you select 'connect'?
to give any assistance we are gonna need more then 'i cant make it work'
Discussion Starter · #12 ·
I have the vgate with the on/off button. But when I hit connect it says obd2 generic,ford,gm & I click ford i chose scan all faults then hit V gate then it does nothing
Discussion Starter · #13 ·
1 - 13 of 13 Posts
