1 - 2 of 2 Posts
Hi I’m new here and I was looking for some help with the installation of my isspro gauges. I have a 95 f250 7.3. I’m having trouble with the installation of the boost and egt isspro gauges, I setup everything according to the instructions, daisy chained the power, ground and dimmer wires between the two gauges, but the gauges do not seem to be getting power. When I tested the power wire itself it was getting power but the gauges seem to not be getting any. If anybody can show me the way they installed and wired there’s it would be much appreciated!
If they are the type that you put the wire into a connector and crimp it before you plug it into the gauge I would check the connector connection and make sure that it is plugged in all the way
Sent from my SM-J737V using Tapatalk
  • Like
Reactions: powerstrokemike
1 - 2 of 2 Posts
