1 - 20 of 30 Posts
I could be wrong but I would of thought my truck would doing better.
I dyno'd it and popped up 539 and 1089 on Dunbars Dyno and then went out to the track and the I couldnt get better then 8.31 with a 60' time of 1.78 and a top speed of 82 mph. All in the 1/8th
With the mods I have, could something be wrong or is it about right?
I wouldn't worry about the dyno numbers. The track time is a little high for 35's and your mods. Even with the 1.78 60 foot. With the same size tires I was running 8.1 with a 1.74 60 foot, and an 8.2 with a 1.80 60 foot.
I wonder if my wastegate needs to be adjusted. I dont know the easiest way to check/adjust it.
Watch your backpressure, it should be around 70psi. WOT. You may need to adjust the wastegate a little to get this reading.
WWDD
so stock pump, stock injectors, what tune are you running a standard 310 or a pump tune 310?
WWDD
Sounds to me like your truck isnt able to maintain rail pressure with the standard 310 (modded 310 has less PW) what is your rail pressure with each tune at WOT?
WWDD
rail pressure is pretty important, go make some WOT runs with everything warm and see what it is, It should maintain 24600, i think thats what honestly killed me on the dyno at the DPC was low rail pressure...
:ford::eek:I remember when his truck was more stock than mine. :bow::bow:
Now I want to know the rest!! lol
1 - 20 of 30 Posts
