1 - 2 of 2 Posts
how do i know if my ipr is bad or not. i put a new icp on my truck now it studders once in awhile and it never did that before :mad:
On my truck i was able to remove the high pressure output hose and install a tee with a pressure gauge and watch my pressure, should have around 900 psi at idle and around 3000psi at wot . Fittings are #6 jic . Make sure u get all fitting tight lots of pressure there. Fittings and gauge are available at hydraulic supply stores . I believe if you took your truck to a international dealer they they can put your truck on a scanner and drive it and watch pressure's
1 - 2 of 2 Posts
