I bought a used SD pump from an 02 that I swapped into my truck. It had the IPR in it also so I figured I would take it apart and clean it up.
Everything seemed to go fine during the rebuild of it but when I fired the truck up after the swap it sounded like a rod was gonna come out of it. I looked down at my Commander and I had 3450 psi of ICP at IDLE.
I swapped the electrical portion (not sure what it's called) with the one from my stock IPR and no change. At that point I decided I might as well put my stock IPR in and what do you know, it runs perfectly. I did not take it appart I just put new o-rings on it.
I do not know for sure if the IPR was working or not but the pump was supposedly off of a running truck that was wrecked.
Anybody know what I may have done wrong when putting the IPR together? I followed the instructions exactly and the tiny pin was put back in the right way.
