1 - 15 of 15 Posts
Busy Busy
Does anyone have the international part #?
dinnerbooter treasurer
I have run the felpro ones that you can get at any auto parts store and they seemed to hold up.
OEM Moderator
The IH and Ford one are metal like a turbo flange gasket. I have had good luck so far with them.
Busy Busy
sure, need 1 for johns motor...
My exhaust manifolds are leaking on my 450 . Which is better install gasket or have it shaved and reinstall with out gasket ? Should I install all new exh bolts? Those bolts must be a pain to get out.
Busy Busy
I'd have them planed and then use a gasket.
Busy Busy
Discussion Starter #15
I cleaned the factory bolts and used anti-seize. #### looks new.
1 - 15 of 15 Posts
