1 - 6 of 6 Posts
A few years ago I replaced my internal orings for oil consumption. And now loosing oil again.
Is their somthing wrong with the intensifier piston? Cheap orings or just worn out injectors?
I've used all kinds of o-rings with good results. I'm not saying they are not a possibility but there is other places you could be losing oil. You could have a leaky oil cooler, bad turbo seals, pcv that is stuck open, is it leaking externally at all?
No external leaks. Loose 6qts in a day drive on the highway. Same symptoms from the internal orings leaking the first time. 5 of the injectors are original
1 - 6 of 6 Posts
