1 - 5 of 5 Posts
I've been noticing an intermittent/random knocking sound from the engine when at fast food drive throughs where the sound can reflect back. Transmission in dive with foot on the brake pedal. If I put it in neutral, the knock will go away. It is in no way constant and comes and goes pretty randomly. I tried putting the parking brake on and getting out but could not duplicate it. Truck runs and drives fine, oil looks good after 3000 miles. I just received a Blackstone kit and will be sending a sample out soon. Any thoughts?
Discussion Starter #2
Found this video on google search. Same noise.
Just replaced my ICP (it was oil filled) and it seemed to resolve the issue. The PO had some cheap aftermarket ICP in there. I replaced with a Ford one from diesel o-rings.
I'm glad that you posted how you resolved your issue. I believe my truck has an after market ICP sensor in it also. I have been thinking about changing it out with a Ford one even though there is no oil leaking from my sensor. I don't have that knock sound, but ever since I got my new tunes I will throw a SES light when I'm in my hot tune. I'm going to scan it this weekend to make sure my HPOP is alright and go from there. Should I go ahead and change the ICP sensor if it's not OEM? I heard the after market ones are junk.
I would for piece of mind. Put the aftermarket in the glove box for a back up. With mine, the knock stated getting worse and cold starts got harder with a decent stumble for the first minute. Everything seemed to clear up with the new ICP. I also have new injector o-rings to put in as soon as I get my new valve cover gaskets and UVCH.
1 - 5 of 5 Posts
