1 - 5 of 5 Posts
Sometimes when I start my truck the SES light comes on and my accelerator pedal won't be active. If I pump it once or twice the light will go out and the truck will rev on the third time. It has only done this once after the truck is running for a while.
Accelerator was replaced by the dealer that I bought the truck from just after I bought the truck.
Bad pedal, bad connection or something else?
Could this cause the hesitation I'm experiencing after a 4-5 hour shut-down?
Hesitation after sitting for 4-5 hours - PowerStrokeNation : Ford Powerstroke Diesel Forum
There can be only one
I'd check bad pedal again, it's the easiest to troubleshoot. Not outside the realm of possibility that you got a bunk pedal
you're not gonna like this but I had the same problem one time and I replaced the injectors, and UVCH and the problem was fixed....my guess was either a bad injector or a bad connection from the UVCH.
Chad
Discussion Starter · #4 ·
I'm a newbie. What is a UVCH?
1 - 5 of 5 Posts
