1 - 2 of 2 Posts
Ran a boost leak test and my intake plenums are leaking really bad whats the best way to remove and reseal? I see that the passanger side plenum has one bolt that looks like it will hit the hpop is that hole slotted?? Also do you have to pull the turbo to do the passanger side? Thanks
un bolt peel them up cleand heads and plenums reseal with the gray goo from ford or IH
1 - 2 of 2 Posts
