1 - 13 of 13 Posts
I am looking at flying to Florida and pick up my truck and swinging through NC to ruddys to pick up some goodies. What does it take to install the tunner? I would like to put it on before i make the 1,000 mile trip home to save on fuel.
<--Under the Knife Again
putting the delete pipe up and 30 mins to download the tunes and u will be good til u get home to add more goodies. Aaron at rudys will get u set up the correct way.
psdguy97
I hear the tunes take a while to load.
the first tune usually takes the longest cause it needs to save the stock file. after that it usually cuts the time in half.
I will probably just put on the tunner and do the rest at home.
sounds like a plan. keep us updated. good luck man and have fun
without the delete pipe? kinda currious what kind of mileage they get just with the tuner. I know it cant be that much better or maybe im wrong
Discussion Starter #9
Not sure about it but i just dont want to break off some rusty bolt and be stranded 1000 miles from home
2010 ASA PRO-4 Champion
I just got my tunner from Arron at ruddys and i got the exhaust at the same time but its coming from somewhere different so I am waiting on that . I installed the 150 dpf on tune and i am just going off the lie o meter but i was getting 9.5 empty and just got back from a 150 mile trip and the lie o meter shows 17.9 and i added tunner with a half tank of fuel i could only get 365 miles out of a tank no matter how i drive it. well after getting back from this little trip its over 400miles on this tank so far with 40 to E so I am impressed so far with tunner . I am going to run a full tank before i switch the exhaust and tunner. then with the 250 no dpf and see the difference.
cool every little bit helps.
Talked to Aaron he said he didn't think the you would see much difference if i don't put the exhaust on too.
1 - 13 of 13 Posts
