1 - 4 of 4 Posts
I got pick up my new sheet metal from the painter later today (fenders and rock deflector) and was wondering if anyone has any tips or info about replacing everything. Also, if wanted I can take vids of the proccess and make a write up since I couldnt find anything about installin the new fenders, thanks!
Sean
Daily Stroker
Did my driver side fender. Keep track of all the bolts and put it back together the same way you took it apart. Start and finish in the same place. Its not too hard.
Use anti-seize on every bolt. It makes it alot easier to take apart later if the need ever arises.
Take the hood off, then the front header panel and lights etc, then the bumper filler, then each fender. There are 4 bolts that hold the bumper filler on, two from the front, two from the back. If you drop the inner fenders, it makes it easier to get to.
1 - 4 of 4 Posts
