1 - 20 of 38 Posts
Is there any thing particular or specific I should do when I install my new hpop this weekend?
JGman141
Go to the store and get an 18 pack first
Atleast an 18, might want to grab the 24 because it's going to be a long weekend LOL
Discussion Starter · #7 ·
Yes I just want to be prepared and first time for install for me so just wanted to make sure I've done my homework... and screw a 18 or 24 pack I got 30 pack in the frig lol... thanks guys!! Wish me luck!
Discussion Starter · #9 ·
Ok so do I need to prime my pump or add any oil straight into the pump before u button it up? Or just put it all back together?
Discussion Starter · #12 ·
so i have put in new pump put everything back together.. truck cranks but does not start.. when cranking showing 1031 psi on the hpop & 33.5 on the ipr... i have checked my fuel pressure that is good also.. anyone know what i can do next or what may be wrong?
JGman141
Make sure you ficm is plugged all the way in, other than that you have enough oil pressure for it to fire.
Discussion Starter · #16 ·
my ficm is showing 47.5 volts... i felt up under it all the harness fell like they are attached good. i did NOT take ficm out when i did hpop install... but i will double check it again make sure. its showing the following codes p0261, p0270, p0276 & p0279 all show cylinder low codes.
JGman141
Possiable harness damage or they may not be plugged in all the way
Discussion Starter · #20 ·
as far as i can tell mine is plugged in all the way. question if it wasnt plugged in completely would i still get a voltage reading? im showing 47.5-48 volts..
1 - 20 of 38 Posts
