1 - 15 of 15 Posts
whats the trick to get it to slide up to get it out from around the top bolt?
I've got head studs but they're doesn't seem to be a clearance issue, I mean it moves around alittle just wont slide up.
Ya I got a rag and got what I could out. What plumbing needs to come off to make taking off the passenger side valve cover easiest.
Are there shorter ones like there are with ARPs? The short ones go under THE injectors and the rest should be the same length
Edward Scissorhand WanaB
No
IIRC the H-11 are all one length. I had clearance issues with the H-11 stud and the injector hold down. Called *** and talked to Zane and he advised to take a grinder to the hold down and remove enough to clear the Stud. Remember which injector s you grind as if you ever remove the injectors you will need to put the ground down injector back in the same hole.
Before grinding on the hold down we wrapped the injector in plastic wrap to protect it from foreign debris.
No
Do you remember how much of the stud was sticking above the nut on your?
1-2 threads which was enough to keep the injector hold down from seating in.
1 - 15 of 15 Posts
