1 - 20 of 43 Posts
Headwind Magnet
I was installing my freshly overhauled injectors from Swamps and the #8 hold-down bolt broke off while I was torquing it down. I'm trying not to panic, but I don't think this is a job I can handle myself anymore. Any advice?
Best,
Jim
Science rulz
Where did it break? Did it break flush with the cyl head or is there something you can get a grip on? If it broke in the threads you're gonna have to pull the engine or the heads I thinks.
Headwind Magnet
Flush with the cylinder head, nothing to grab onto. That would totally suck to have to pull the head or motor...
Senior Veteran Member
:eek: Not good. Might be able to extract. I would consult a machine shop or someone with more experience. I would think ( and hope ) you could drill out, extract and reinstall a new one afterward, but see if someone on here posts a more in-depth reply. there are a lot of VERY knowledgeable people on here. Just my $.02.
What else?
Try using a small pick and hammer to twist it out.
:whs: See if it is loose in the threads, it may come right out with some patience. After that I would try a left-handed drill bit, they work pretty well for backing out broken bolts.
Dave
Headwind Magnet
Discussion Starter · #7 ·
Guys, thanks very much for the replies! Glad to see you guys think its possible to fix this without pulling the heads/motor.
I will give the pick/hammer thing a try. Maybe I'll get lucky. Up to now, if it wasn't for bad luck, I'd have no luck at all with this truck. I thought I bought a clean truck less than 2 years ago with 62000 miles but its been one problem after another. I sure hope to put that all behind me with a Swamps overhaul on all 8 plus the IDM.
Going into this job I was concerned because I had to replace the #6 injector cup. Thanks to some great coaching from Jonathan at Swamps it was a lot easier than I thought. I was torquing down my last injector on this install when the bolt snapped. :doh:
I figure I'll give it a careful try. My out is flatbedding it to my local garage. They're not PSD specialists but they are the best in the area and very honest. I stopped in today and they are confident they can get it out. I just don't want to do anything in ignorance that will make the situation worse.
Let me know if you guys have any other ideas or advice...
Best,
Jim
Premium Member
Hey Jim~
you should be able to spin it out with a pick tool or similar...
worse case a LH drill bit would most assuredly get it.
Headwind Magnet
Discussion Starter · #10 ·
Centx and Dave, thanks! I'll give it a try...
Best,
Jim
Dairy Mechanic
Same thing happen to me but on #1 cylinder. I drill a small hole and took the tap to it and got it out. :D But the #8 cyl will be harder.
Headwind Magnet
Discussion Starter · #14 ·
Mike and Magnum, good to here this has been done before, thanks! 90 degree drill and left-hand threaded bit may be the answer...
Science rulz
There are left hand drill bits aswell, that might get it.
Also the "chisel" approach usually works pretty good too.
All done now
Just pack the area around it with some oiled down rags to catch any bits of metal. No beer till it is out. Take a deep breath, let it out slow. Repeat until heart rate is down to normal. Start on it. Repeat the deep breaths every five seconds. GO SLOW.
I haven't used a left handed bit on a broken bolt in years. Put a nut over the top of it, grab the MIG welder, and weld the nut to the broken bolt.
Headwind Magnet
Discussion Starter · #18 ·
"No beer till it is out."
LOL Thanks for the laugh Andy, just what I needed!
Good advice about the oily rags.
Boon, thanks but I don't know how to weld. I've always wanted to learn...hopefully someday.
Thanks Colt. You guys have convinced me I should at least try before I resort to taking it to the garage. I can't touch it today cause we've got a house-full of people coming over. I'll keep you posted.
Happy Easter to all!
Jim
1 - 20 of 43 Posts
