1 - 3 of 3 Posts
I bought a truck with upgrades, I was told it had aftermarket injectors but they were unknown. Due to issues I had to pull the all the o-rings are fried. On the side someone used an engraver and wrote P1210- 70hp I would assume they are 70 horse injectors but other than that I have no idea.
Search for p1210 is just coming up with the engine trouble code not a part number or anything.
To get my chip tuned correctly I'm trying to figure out what I have single or split shot etc.
Flow testing them is not the best option since I need and use my truck daily.
Only thing I could think of was to try both ways or both tunes see which one worked better???
Thanks in advance
Its hard to write tunes when the injectors are unknown. They need to know the specs, not just if they are splits or singles. You would be way better off in the long run having them flow tested and gone through by a vendor on here.
Id call around to different injector builders and see if the numbers sound familiar.
1 - 3 of 3 Posts
