1 - 20 of 31 Posts
Ive Looked around and all ive heard of is adreneline and swamps pumps, im running stock injectors, i keep getting codes thrown from the ts chip. i was wondering what would be a good one to run with the possibility of maybe stage 1 or 2 injectors
I have a T500 from Terminator Eng. and I'm running 238/80 hybrids with no problems.Not expensive either
srp1
F250 Black Cloud Edition
SRP1
Subject Matter Expert
Its probably been explained else where but can someone give more info on the t500? santa brought me a scanguage and now I see im only holding 2450psi at wot. :(
SRP-1 FTW.
Discussion Starter #9
Will the terminator work ok without upgrading the injectors and do I have to upgrade any of the hoses or anything else when I put the new hpop on
Ticking time bomb
All you srp1 guys you can't even get that pump right now can you? And no you don't gotta upgrades hoses or anything.
Terminator..... Hands down
Horsepower Enthusiast
It will be back out sooner then most people think.
The SRP1 or the Stealth stage2-3 badass looking aluminum pumps?
I'm looking to upgrade mine as well along with some new injectors, only planning on a "stage 2" type injector and something like 400-450hp.
I figure if I have to replace it I should use something a little better than stock. :D
the stryker god
srp1 will handle those injectors easily.
Oooo, White Lightning !
Terminator....
Davey B
I wanted an srp1, but didn't feel like waiting that long so I bought a used stock hpop an sent it to joey to turn into a t500. I went this route in case the t500 didn't hold, I'd still have a core to send in for an srp1. So far though I'm really happy with my t500. I haven't hooked it up to a scan gauge yet, but there was definitely a noticeable gain. If someone wants to come over an data log my pump, they're more than welcome, but I'm happy with it so far. Down the road, I may up my nozzles an might need a different pump at that point. The srp1 seems like a great pump, but I didn't feel like waiting an Joey was able to get me my pump right away. I think the t500 doesn't get the credit it deserves, its cheap an flat out works
1 - 20 of 31 Posts
