1 - 20 of 64 Posts
· Registered
95 f350 7.3 manual
To preface....I'm waiting for my code reader to show up, but figured it won't hurt to get this started.
I was heading to work when I lost throttle response for about 10 seconds.....then it abruptly all came back online. After that I tossed a new tps in. Truck ran a Lil rough for the next feways. Had a few sputters at rev and she fell on her face at an idle a few times. (It happens to be the coldest week of the year up here) I assumed I was having issues with gelling. This went on for a few days. I got to work Wednesday morning and shut my truck off. It will not restart. I have confirmed I'm getting fuel.
I've checked my oil both on the stick and in the hpop. I replaced icp and pigtail, then the ipr valve . Then thought maybe it was the cps. I read on here that in the obs as a quick check for the cps, when you crank the truck over the tach should move. But I'm curious about how much? I mean should It be reading rpm, or just a faint bump.
Outside temp has come up to high 30s into 40s since all this started last week.
Any ideas would be appreciated.
Thanks
Sent from my SM-S908U using Tapatalk
· Registered
Is the CEL illuminated? Does the Wait-To-Start light come on? What's your fuel pressure when cranking? It needs to be a minimum of 25 psi at a minimum crank speed of 100 rpm. I would get a new OEM CPS and replace it. If it doesn't solve the problem, you at least have a spare for the glovebox. Hopefully the code reader is compatible with our trucks as most generic readers won't read these trucks. Cheers!
· Registered
95 f350 7.3 manual
Lol, I guess it would be helpful if I would have included that. The cel came on when the throttle died that first day. But it didn't stay on. The wts light comes on and gp's seem to be working. I did have a blown fuse (#3 -30amp) but I think that's unrelated. The tach barely wiggles during cranking, I put in new aftermarket cps, but ordered a few of the "gray purple" oem ones. Sounds like I'm dead in the water till the scanner and cps get here. Noticed that relay 2 controls idm , so I might toss a relay in tonight. The truck had a glove box full of spare relays when I bought it, maybe PO knows something I dont.
· Registered
95 f350 7.3 manual
Discussion Starter · #4 ·
I've got a regulated return system, fuel pressure is at 60 psi when cranking.
  • Like
Reactions: Jax
· Premium Member
99 & 00, F350s, manual and auto, Ext & Crew Cab, 4x2 & 4x4, need more room!
Welcome to PSN! @Jpchaos
I hope you got an OBDII and will be using FORScan! As @Patrick Feeley said, "Hopefully the code reader is compatible with our trucks as most generic readers won't read these trucks. "
1. Get FORScan scanning software for Fords (free) and an OBDII reader. Greatest troubleshooting tool ever!
2. DO NOT throw parts at it . . . if you must, then make them Motorcraft parts. Ford diesels are quite particular about their sensors.
3. Come back with the codes. Lots and lots of smart people here!
Your signs sort of, kind of, remind me of a truck that wants to go into limp mode. It could be anything causing that, from the cold weather to wiring to sensor going bad. Please tell us about your truck, mileage, background, transmission, etc.
What you can do while waiting for the ? code reader -- Can you plug your block heater in? Can you put a heat source near the front bumper so the heat goes to the engine? Have a a gel-preventative additive? Rule out the simple stuff [It's too freaking cold!] first.
  • Like
Reactions: scotty.vincent
· Premium Member
· Registered
95 f350 7.3 manual
Discussion Starter · #7 ·
Per your advice on my intro post I bought the forscan and the reader that was listed in the link. Block heater is plugged in and engine is warm. I've had the truck since July. 95 f350 7.3 5spd manual. Crew cab 4x4. 325000ish on the truck 125000 on motor. The PO was great at oil changes (have recipes) but sucked on all other routine maintenance. I've been slowly going through it. I don't run a gel additive as the fuel is treated this time of year. Also popped a line off the regulator and it's definitely getting fuel. I replaced the hpop lines in July and and the fuel pump(rail mounted) and uvch in September. That's all I can think of, so please ask more questions.
  • Like
Reactions: Jax
· Registered
95 f350 7.3 manual
Discussion Starter · #8 ·
Please reconsider this statement.
According tohttps://fuse-box.info/ford/ford-f-150-1992-1997-fuses-and-relay
#3 - 30A is the Idle position switch (Diesel) fuse.
Also, consider, why did it blow? Look at the associated wiring - something may have worn through and shorted. Trust me, that can screw you up for a while.
I believe it was a short from the original fuel bowl heater that caused that to blow, but could be wrong. I've re taped all the wires and replaces the fuse.
· Premium Member
Dang it, I thought your UserID was familiar! I couldn't find the post, though.
So that's the code reader you are waiting for? Good on you. But, we do need the codes.
When you search for the codes, use a term like Ford Super Duty code A#### because you can get some weird responses sometimes.
· Premium Member
By the way, do you have schematics? If not, consider this:
I bought his 99-01 schematics. They are in .pdf form and easy to use. $3.95. He emails them to you.
I paid $180 and $260 for the Ford books. They aren't as good.
· Registered
95 f350 7.3 manual
Discussion Starter · #11 ·
Yep that's the one
  • Like
Reactions: Jax
· Registered
95 f350 7.3 manual
Discussion Starter · #12 ·
Done
  • Love
Reactions: Jax
· Registered
95 f350 7.3 manual
Discussion Starter · #13 ·
I really appreciate all the help guys!
· Premium Member
Check your ebay messages. He will ask for the email address he is to send to.
· Registered
95 f350 7.3 manual
Discussion Starter · #15 ·
Also worth mentioning only as a gripe really.......since I got this truck the engine temp Guage hasn't read normal. It stays within the block on the far left. Just figured it doesn't work and added it to my "to do" list.
· Registered
95 f350 7.3 manual
Discussion Starter · #16 ·
I included it in the memo, but will do. Thanks.
  • Like
Reactions: Jax
· Premium Member
I don't know if this will work for you, but out of my 1999 manual:
Font Circle Number Rectangle Document
Most gauges / sensors work this way.
So, check the resistance of the sensor when cold.
Check ^^ again when it is warmed up.
Test the gauge -- find a resister greater than the resistance of the warmed up truck -- like, if it was 16,000 find a 20k resister. Put that between the two wires of the plug. See if the gauge shows higher.
If the gauge shows higher, you need to replace the temp sensor. If the gauge does not show higher . . .
Well, you could try moving the needle on the gauge spindle to the 1/3 mark on the gauge. Not sure how hard it is to replace a gauge.
· Premium Member
1995 Ford F-350 7.3 PSD
I'll see If I can find a diagram for that when I get time
· Registered
95 f350 7.3 manual
Discussion Starter · #19 ·
Update....got home kinda late last night, swapped out that #2 relay and checked all the fuses . 22 was questionable but not blown, so I swapped it out. Still nothing, although the tach does seem to move a Lil more wile cranking. I am beginning to fear I have a bad ground or a busted wire somewhere.
· Premium Member
What was relay #2? Also, unplug the Injector Pressure Control (IPC) sensor [front left head oil-rail] and see what happens.
Ford diesels get cranky about their sensors. Pull the plug from the Crank Position Sensor (CPS) and check the wiring.
One "issue" (my term) with the Ford wiring is that the wire can be broken inside the insulation but the insulation looks okay. A sharp bend will be all it shows. [Unlike my GM experience where the insulation cracks and breaks off so you have phantom shorts everywhere.]
Carefully cleaning and checking each of the sensor wires will go a long way.
1 - 20 of 64 Posts
