1 - 4 of 4 Posts
how do I test my IDM in a 97f250 4x4 manual trans? will a 99 f250 4x4 auto trans work in my 97?
Discussion Starter #2
what voltage should be at the plug to injector (gasket) with key on in run position?
Premium Member
all 94-2003 7.3L IDM's have the same output voltage from the factory, though there are 4 different model numbers.
They are interchangeable.
To check voltage, you'll need an oscillioscope, as the voltage at the injector wiring is a PWM signal...so a (normal/DVOM) voltmeter won't be able to 'catch' the short (.002s or shorter) signal from the IDM.
if you have an oscilloscope, you will look for a signal that looks similar to those shown here, stock 94-03 IDM's output 110vdc regardless of the IDM model number.
7.3 IDM and Injector Waveforms
1 - 4 of 4 Posts
