1 - 20 of 22 Posts
possibly going to buy the modded idm from beans. anyone have it? is it worth 100$? where is the idm located? how do i remove/ install it? do i have to have any soldering done or is it just a bolt-in rplacement of the stock? thanks in advance.
Premium Member
its located on the drivers side fender above the wheel well, mine was only held on with 3 bolts but looks like its suspossed to be 4.
<---F350 DRIFTER
You won't have to do any soldering if you buy from Beans. Just swap em out.
Yep, your just sending your IDM to Beans, they do the modification and then send it back to you. And its worth it.
I know nothing...
"Worth it" is relative, mine was $0.25.
The improvents are noteable but not huge. It will start easier and have a crisper pedal feel.
This is true. If you know how to solder, you can DIY for less than a dollar. However, you screw it up, and you just gambled 300 bucks on a new IDM.
im fairley mechanically inclined, however soldering isnt my specialty.
Beans can handle it :)
Im doing my own this week cant wait!
I really wanted to do this mod, but can`t find anyone local that has the resistor`s. Does anyone with a chip have this done? and if so did it help? Good luck with the idm from beans post back and tell me how it works. Roger
Discussion Starter #14
will do roger
I know nothing...
1 of mine is stock tunes and straight pipe/DIY intake and it runs good. The other has a DP, TW/TS, intake and straight pipe and you can't take off with more than 1/2 throttle w/o frying the right rear.
^^^^^^^^ the tw truck has 4.10s right?
where could i find the info to do the idm mod? my search wont work
i spent the money to have mine done and beans shipped it back and cant say i can tell any difference? sure hope they did the mod and not just send it back stock:shrug:
Was that on the 99? Cuz its not much of a difference from 120v to 140v where as the OBS trucks are jumping from either 100 or 110 to 140.
1 - 20 of 22 Posts
