1 - 20 of 54 Posts
Anybody know how to do the idm mod, what resister to put in?? and have a link to a diagram or something to walk threw it
Need a ride.
I thought that the early ones were like 90 and the later ones were 110 or something like that. And the modded ones were being increased to 140! I am curious if this makes a big difference with bigger injectors? Or if it is very noticeable?
Here is a link to the instructions I used
I bought the resistors from Mouser.com 0.14 ea but $6.00 shipping
For the replacement resistor, I placed an order with Digi-Key corporation. The resistor is a .5W 73.2Kohm 1% metal film. My IDM is an IDM 120. IDM 100 and 110 require a 75Kohm. how do i know which one to use?? i want to do the 140 mod
Mine is an IDM 120 and I used the 73.2k resistor. After i did it ,I did notice some improvement ,the pedal seems more sensitive.
Need a ride.
I know in my 03 I have the stock 120 resistor that can be modded to the 140. I actually had my IDM out but when I seen how close and no room for error the job needed, I wussed out, plus my soldering pen tip was to big for the job so I buttoned it back up, sealed it good and forgot about it. Here's some info I heard thru the grapevine, very reliable info. If you plan on a injector upgrade, its best to leave your IDM alone, with the proper tuning, all these varibles can be taken care of by your choice tuner.
I can't see how more voltage is a bad thing with these type injectors different calibrations, upgraded injectors or not.
Well Hung Member
search the swamps high frequency idm, thats what im running,... good explanation of the differences, and what the 2 different ones do on the thread,
I didnt the mod on my idm it starts better and faster off idle glad best .17 cents mod you can do ha ha
All done now
Local Radio Shack.
All done now
What size do you need? I can see if I can source them here. Postage stamp shipping.
I know nothing...
If you want to order go Digi-key and buy 200, then mail'm out for buck apiece.I got mine from a ele supplier in KC, it's about 2-3 times bigger than the Vishay res DK sells and won't vibrate loose. Pack of 6 $1
1 - 20 of 54 Posts
