i just finished putting a '97 powerstroke together for a customer and have a new problem.
the truck came in with a lack of power and a miss. turns out 1 injector had a bad plunger and barrell. while we had them opened up i installed a set of machined intensifier pistons to make 160cc injectors. i also converted it to a super duty turbo and put an intercooler on it. i built a 3.5 inch down pipe and put a 4" straight pipe on it as well.
i got the truck running and took it out for a test drive and to work the air out of the injectors. the truck was starting to run good then i blew off an intercooler pipe. after fixing that i took the truck back out.
at about 2200-2400 with my foot in it, the truck feels like it is blowing a i/c boot off again but it is not. at the same time this happens the truck throws up a wall of white and blue smoke and the truck falls on its face. if i let off the throttle the smoke goes away. then i can get back into the thottle and all is good again till about 2200 rpm and it does the same thing.
it will do this repeatedly. and, every time if i take my foot off the throttle, it clears up and runs fine. the truck idles perfect and runs very smooth and clean right up to this point. with low load it will rev all the way to 3600 without a hiccup.
if i keep my foot in it, the smoke only gets worse and makes no power.
i dont know what to do here. i NEED some help figuring this one out.
thanks
barry
thanks
barry
