1 - 9 of 9 Posts
i am only running 8 MPG. i put a s&b cold air intake on my truck and a diamond eye exhaust and only pushing 8 mpg. I just got the truck as a hand me down in april but previously it sat for almost 8 years and before that my dad would use it as his heavy duty work truck. He kept up on oil changes and basic maintenance but never thought about adding performance. Might i add it pulled a 500 gal water tank lots of chemical all over the montana country side. I know for a fact it has leaking up pipes and at least one injector going. i haven't chiped it yet but in time i will. Is there anything i should look to buy to help increase the MPG.
Administrator
i would start by making sure no brakes are dragging get them up in the air stand on the brakes and let go then see if the wheels spin with minimal drag
or even a temp gun should show a hot brake after a drive and may pinpoint an issue
and of course work on the exhaust leak and I bet injectors will help a ton a chip is a must but not so much for MPG lol
what injectors do you suggest
Super Moderator
Let's hold up a minute. Injectors could be the cause but you need/ want some upgrades before going there.
As zmann said check your brakes. Also look for leaking up pipes, boost leaks, stuck ebpv. How old are your filters. fueland air. How oil is your oil. How many miles on the truck. Do you have any modifications.
Moderator
Post #7 summed up most of the things I'd recommend.
These Super Duty trucks are notorious for sticky brakes. Not enough to get really hot and let you know there is a problem, but enough to sabotage your MPG although eventually they will get hot and cook a rotor. The rear brakes are the worst and are hardest to catch. Dry graphite lube on the slide helps.
I've fought my EBPV. The damned thing would stick shut for months. It's like driving with an exhaust brake all the time. I finally electrically disconnected it when I knew it was open. It takes a while to warm up but at least it runs efficiently.
Make sure your 4x4 and hubs are disengaged. They are a lot of drag.
Other guys mentioned maintenance items and they are right. Also inspect for fuel leaks between the tank and the filter. I've never had this problem but I've heard of guys who did have it.
The big tires are not doing you any favors as far as MPG is concerned.
Eastern or western Montana? Terrain matters.
Speed matters a lot; but I know in the West the sheer distances dominate your driving style.
Unless you have 4.56 gears you should get better than 8 MPG.
I have a 97 7.3 e4od. Stock except for 3 inch downpipe to straight pipe. Did new front brakes and that is all. Running 285/75/r16' mud tires with 4.10 gearing. Driving conservatively I will easily hit 20 mpg on the highway, even going from sacramento to truckee. The key is driving it well. There are few if any other ways to increase fuel economy. I drive 55 if it is flat, speed up and gain speed down hills, and slow down going up hills. My throttle position barely changes in all these situations. You must use your momentum from downhills to be able to go up the hills without laying into the throttle. My friends and I went up to truckee this last weekend. They went 70-80 while I used this method. Surprise Surprise I got just under 20 mpg through those steep hills. Their Tacomas and Jeeps with small tires got no better than 13. Took me around 30-40 more minutes. I saved 25 dollars in fuel as compared to them. Ask yourself, is an hour or so minutes of your time worth 25 dollars? I think so. Other thing is to turn overdrive off when you begin to lug in overdrive. The PCM downshifts too late. Lugging in overdrive up a hill wastes more fuel than revving higher in 3rd in many situations.
1 - 9 of 9 Posts
